How to get rid of these Trojans
How to get rid of Trojan Horse Downloader Dyfica AC Trojan Horse Downloader Dyfica AJ and Trojan Horse Downloader Wintrim AD?
My anti virus is not cleaning all of them.
Hi Edson,Â
Very sad to say that Huge loads of Malwares and or Viruses are Playing with your system. You must be very careful while using External devices to install Softwares and other stuffs and also while using Network.
If you have all these viruses on your computer then your computer is surely performing very slowly. Since it is obvious that your computer is heavily infected with viruses, you need to use Sophos Virus Removal Tool. This tool is designed for use on computers that are already infected with viruses. Some antivirus programs become useless when the machine has been infected with a virus.
This tool does not intend to replace your antivirus. It is not an antivirus that monitors your computer for different threats. You don’t need to uninstall your antivirus when using Sophos Virus Removal Tool. It runs alongside any antivirus applications you may have. When installing, don’t disconnect your computer from the internet because it will automatically update its virus database right after the installation.
When it is installed, run it and start scanning your machine. When a virus is found, remove it and then repeat scanning until it no longer detects a virus on the computer. If you think your antivirus is weak, try using other programs. You can try Norton Security. It is formerly known as Norton Internet Security and still has the 30-day trial period. Another one you can try is ESET Smart Security.
