How to get rid of useless application and games?
Remove Unwanted Programs From Windows:
Step 1- Click Start in the Left Corner of your screen, then navigate to Control Panel
Step 2- Double click the Program and Features button
Step 3- Select the unwanted program you want to remove
Step 4- With program selected, now click uninstall text
Step 5- Follow the uninstall instruction, and then click finish button.
We all usually install many numbers of soft wares as per our necessity in our PC. As a result the system performance will be decreased. So we have to uninstall the unusable or useless soft wares. To carry out this task there is a software known as Revo-Uninstaller. After installing Revo-Uninstaller, it will show all the installed soft wares. The only thing we have to do is browse unusable soft wares one by one and then uninstall them.This Revo-Uninstaller not only uninstall unusable soft wares but also deletes all the information related to uninstalled soft wares even in the system register. So with this Revo-Uninstaller we can utilize the system space in an efficient manner.
Similar tool for the same is PC-Decrapifier.
Hello Casey,
If you have a lot of useless application and programs installed in your computer system, you can easily remove and uninstall it by following these steps.
1. Go to Control Panel
2. Click Programs
3. Click Programs and Features
4. Choose the application or program that you wish to uninstall
5. Then click Uninstall
6. Then the Uninstall Window will pop-up
7. Just follow the instructions to finish
8. Finally, click finish
Ware
