How To Get Rid Of A Virus On Your Computer
Hi. My PC has been working slowly for a few days. I think it is because it has been infected by virus. How to get rid of a virus on your computer? Please reply ASAP. Thanks in advance.
Hi. To learn how to get rid of a virus on your computer, you should first perform a full system scan. Before you do this, take a backup of all your important data to ensure that no data is lost. Next, do not just go on believing that because the PC is working slowly, it has been infected by virus. Make sure that all the other programs are checked as well to ensure that there is not a problem with any other program. You should have a good anti-virus but in case you don’t have any, then, going for options like Kaspersky, Norton will be fruitful.
Next, reboot the device Next, make sure that the reboot takes place in the safe mode to de-activate the viruses making them easy to find and kill. Then, run the full system scan after which restart your PC and check if the problem still persists. The virus can be removed manually as well by using the Auto runs software.
Hope we helped.
