Denise_Pha
10 points
Posted on - 08/25/2011
Every time I open something in my computer or change anything in my computer, like opening control panel, or trying to install something, something pops up, that Windows needs my permission to continue.
It is really annoying and it makes me think that I am not the administrator of this computer. I am the legitimate owner of this computer and I don't want it to pop up every time I change something in my computer.
Can anyone help?
How to get rid of Windows admin pop up
Hi!
You should go to Control Panel > Action Centre;
Then on left top of the page click on Change User Account Control Settings;
A new window will appear;
You can see a seek bar, move it to Never Notify.
Restart your PC.
Your problem is solved!!!
Well you can try to do the following for Windows 7 Go to Run from start > msconfig > Tools tab > Launch > Disable UAC (just move the meter to don't notify) > Save This should block any UAC pop ups whenever you try to launch any application I hope this helped Regards Welch Sanger.
