Hi Experts,
I am having a system built in vb.net and with a payment gateway. I want to get a salary slip sample with editing options. Currently I cannot edit slip sample. I think code should be edited. Give me the code to edit salary slip.
Meagon Williams
How to get salary slip sample with editing options?
You can try the following to get a salary slip sample with editing options:
1. SolveigMM Video Editing SDK 1.0 – This a free software and can edit salary slip. You can download it here – http://www.solveigmm.com/en/products/video-editing-sdk/
2. SampleNet 4.28 – It is a very effective tool with editing options. It also supports vb.net. You can download it here – http://www.ibuyer.hk
3. Lohnabrechnung Lohn 2006 6.0 – This is another free software that helps you edit salary slips. You can also maintain your accounts like salary, payroll, etc. All your employees records also can be stored in this software. You can download it here – http://www.ipsource.ch/
Hope this information helps you.
