How to get simple eBook template designs?
Can anyone help with how to get simple eBook template designs and can you include some related templates as well?
Hello Joseph Abbott,
It is required to you to get simple eBook template designs. You can get it from some site. To download simple eBook template designs go to the following link. Click the following link and choose your design. The link is https://graphicriver.net/item/simple-ebook-template/136253. Here you will get many designs. Thanks.
You want to get simple eBook template designs you can get it from some site. For download the template you have to go below link. Please click the below link and choose your design and download.
The link is-
https://graphicriver.net/item/simple-ebook-template/136253. There are so many design here.
