How To Get Snipping Tool On Windows 7 In Simple Steps
Hi. I have to start using the snipping tool. Also, I want to know the different types of snips available. How to get snipping tool on Windows 7? Please reply ASAP. Thanks in advance.
Hi. To learn how to get snipping tool on Windows 7, click on the start button and then select the control panel. Then, click on the programs following which select the option for turning the features of Windows on or off. Then, to continue, click on the continue option. To enable the snipping tool in Windows Vista, make sure that you have marked the option for tablet-PC optional components. When you are done doing the settings, click on OK.
The various types of snips available include a free-form snip to enable drawing a free-form shape, drag the cursor and draw the rectangle using a rectangular snip, selecting the browser window which you want to capture using the window snip and in case the whole screen is to be captured, use the full-screen snip.
Hope we helped.
Notifications
