How to get a software for outlook Plugin backup contacts?
Hello Experts,
How to get a software for outlook plugin backup contacts? I need to download the best software that will enable the user to export outlook files to become a backup for contacts. I hope you will share your ideas and experiences about this topic. Your help will be much appreciated.
Best Answer by nisnisbotchog
Answered By 0 points N/A #187013
Hi Trevor,
You can download ABF Outlook Backup, it's easy to use and advisable if you're a beginner, like me. ABF Outlook back up is not only for saving your contacts, but also, your emails, settings, folders and almost everything in your outlook. You can also set a password for your back up files, so you can protect it.
ABF Outlook Backup would not require you to have additional software because you can save it on your hard drive or cd, and by doing so, you can transfer your files from one computer to another.
Hope this helps.
Answered By 60 points N/A #187015
Hi, Trevor Jhon
As I have read your concern. I got a solution in your problem. You must be very resourceful in finding the best solution in your problem. Read some articles and posts of others Outlook user's on different sites.
I can suggest you some good forums, which are listed below:
