Angela King
10 points
Posted on - 10/23/2012
Hello experts,
How to get some Samsung wave y neon theme?
A licensed freeware or shareware version will do as long as it is a secure one, I don’t want to compromise my computer desktop with an operating system of windows XP.
I know you can share with me the best idea you have.
Thank you experts.
How to get some samsung wave y neon theme?
Hi angela. There's a lot of downloadable sites where in you can get free themes for your Samsung wave y.
Here are some suggested sites i could recommend you.
Good Luck on your search.
Samsung Wave Themes
Hi Angela King,
There are lots of sites out there that can give you a theme like that.
The thing you must have, of course, is antivirus software, but if you’re going to use it in your desktop I don’t think it will run like the way it operates in your phone.
Here are some sites where you can download such theme:
Download Free PC Manager Software. Easy File Transfer.
Free Samsung GT S5360 Galaxy Y Neon Lights App Download in Themes & Wallpapers & Skins Tag
