How to get started in Windows 7?
I know how to set up similar programs in Windows XP, but I recently installed Windows 7 and I don’t know where the options and settings in Windows 7.
Somebody help me.
Somebody help me.
Hello Marry,
If you need to install programs on windows then the process is not that different to how you were installing then in windows XP. All you have to do is get the right applications for the windows version that you are using, by right applications I mean getting a 32 bit application if you windows 7 version is 32 bit and so forth, and then run the set up to install the program.
You can install the programs from a CD or from a USB flash drive. You can download some of the applications from the internet, for those that are free but for the commercial ones you will need to buy a CD containing them and install the programs.
Hope this helps.
__
Regards
Lee Hung
Notifications
