How to Get the theme properly on my CM9?
I am trying to load the MiUI theme on my CM9.
But an error occurred for P500.
Can anyone give me an idea on loading this theme properly on my CM9?
Hey frank,
It would have been better if you had also posted the error received while loading the MIUI theme on your CM9. Nevertheless I shall brief you with the necessary steps to be followed while doing so.
Firstly make sure you have downloaded the ROM zip, Google apps and the FLASH GAPPS file onto your device. Also make sure your phone is rooted and CLOCKWORKMOD installed in it to take it into recovery mode.
Clear the DalvikCache through the advanced options in the recovery mode. Now, choose install zip from SD card. Finally go to the clock recovery mode page again and reboot.
You should reboot again in recovery mode to install the Google apps by using the FLASHÂ GAPPSÂ to flash it.
Follow these steps and you should be good to go. Reply back with the error if it still persists.
