Some schools and colleges, for security purpose or to save the children from being addicted to a social network, block websites like Facebook, Twitter, etc. These sites are usually blocked to keep away children from getting into wrong means. But if you dare to access them inspite of the restrictions then, how to get into websites that are blocked?
How To Get Into Websites That Are Blocked
There are many ways to access blocked websites. Some of them are as follows:
1) Use IP in place of URL When we block websites, computer stores their URL (www.facebook.com, www.gmail.com ). So you can write the IP address and access those sites. You can get the IP address from the command prompt by using the command ping domain.com.
You can even use Tejji.com for finding the IP address.
2) Retrieve the site using email You can send websites to your email via Web2Mail service. This service is free and you just have to send a mail to [email protected], and the subject should be URL of the site you want to access.
3) Using Nyud.net You can unblock websites by just adding nyud.net to the URL. If Facebook is blocked, add nyud.net to www.facebook.com,, and you can then access to Facebook.
