How to get wmv stereo convert to flv?
Hi Experts,
I am in need of  wmv stereo convert to flv urgently.Can anyone tell me how to get this done?I am looking for a software preferably  freeware to achieve my target.The format should be vital but video must be working without any hindrance.Thank you.
Kaitlynnnatasha
Best Answer by Toni Linscomb
Answered By 0 points N/A #131407
Greetings Kaitlynnnatasha! My suggestion for you is to use the Any Video Converter. This Converter supports most of the media file extensions. And for me this is a great tool for converting my Video files because this program has everything and all the features that i need for my video conversions.
Cheers!
Answered By 5 points N/A #131408
Follow the below steps.
1.       Download and install FLV converter from below link.
http://download.cnet.com/Xilisoft-FLV-Converter/3000-2194_4-10871678.html
2.        Add WMV files.
Click "Add File" button to load your WMV files.
3.        Set output format and output folder.
Choose the file you want to convert, Click "Profile" drop-down button to choose "FLV – Flash Video Format (*.flv)" as your output format.
After choosing a profile, You can adjust parameters by clicking the "Advanced Profile Settings" button.
Click "Browse" button to choose destination folder for saving your converted FLV files.
4.        Start to convert WMV to FLV.
Click "Convert" button to start the conversion.
