How to gif files wallpapers
I have a gif image that I want to set as wallpaper. The gif image is too small and when I stretch it, loses quality. Is there any way to maintain its quality while stretching the image to keep it as desktop background?
There are other tools like Bionix desktop wallpaper changer which is for windows 7. It is a free ware tool which can be installed easily and can be used. You can put any sort of image into it and it will work fine. There is an option in windows 7 also where you can split the gif image frames and play them as a slide show which will help you to experience the same gif animation in slide show.
Please ensure to change the time delay. Bionix will work fine for you I guess. One more thing it may not be possible to increase the quality of image which is in Gif format, You need to find images of those and play them as a slide show.
Hi, There are many program software can be use to resize the image in different file format. I advise you to use Adobe Photoshop. This software brings high-tech imaging magic, newest artistic options, and gives fast performance.
Use this software to resize or stretch any format of images like GIF image, it will not loses the quality but it will maintain its quality.
Best Regards,
Heather marie
If the file size is small and there is no way to resize it then, it’s a bad news for you. Gif images comes with an specific runtime with its borders. It only play with its original size. If you want to resize it, it will be faded.
You can set it up as a wallpaper but it will not work. It will be faded and doesn’t move. So, I think the only way to set this wallpaper is set as real size.
Notifications
