How to give a fixed background image on a web page?
Don’t worry. As a new beginner, I recommended you to read more and more article as you can. You can also download more and more eBooks on Html and PHP. You can also visit this web site to know more information.
Now open your web page in notepad or Dreamweaver ; then in the <body> tag set the background like this <body background=”(your background name.
You have to save the image file in the same folder)” (and to fix it)BGPROPERTIES="FIXED" >. Now for example <body background= “picture.jpg” BGPROPERTIES=”FIXED” .
Hi Miron,
You are looking to adjust an image to the background of your website so there are several ways in order to do that in html code. Following are the method through which you can adjust the background image in html code.
<body background="miron.gif">
Here you are just inserting the background image "miron.gif" to make it appear on webpage's background.
<body background="miron.gif" bgcolor="blue">
You can further make them more interesting by using the css script. for example
Here your are changing the main background color which will appear when the background file is not fetched to the browser.
These are background tag's properties which can have values like for background-attachment can be assigned a value =
Background-image can be assigned one of the following values.
Background-position can be assigned one of the following values.
Background-repeat can be assigned one of the following values.
Even Background tag itself can be assigned one or more of the following values simultaneously.
Happy scripting.
Hope this might help you.
You can change the background of the image, on the web page. Use the CSS solution, that can be created on the background image and this can cover the fixed background in HTML tag. You create a web page in single background that can not be tiled in the background. Check the code below for the properties in the fixed image background and edit the text indicated as needed.
<body background ="yourimage.gif" bgproperties="fixed">
Checks this 2nd code below, for the body can be moved over the image background and can prevent an image from repeating.
<STYLE TYPE="text/css">
BODY { background-image: url(yourimage.jpg) }
BODY { background-repeat: no-repeat }
BODY { background-position: center }
</STYLE>
