How to go to Opera mobile clear all prove data?
I am trying to sell my Samsung s2 with opera installed as its search engine.  My problem is I can't delete my browsing history (global_history.dat) and cookies (cookies4.dat).  I can't even delete my log-ins in different websites.  How do I go about Opera mobile clear all prove data problem?
Answered By 0 points N/A #149090
If you want to sell your phone, the first option is to reset your phone into its factory setting. Then if you can uninstall the Opera mobile app, go do it. In this case, you can be sure that all your private data are cleared and it makes your phone's system look new. If the Opera mobile app is the default browser, go to the app's privacy setting and clear the history and cookies manually. The files global_history.dat and cookies4.dat are the ones that store the history and cookies. You can't delete them but all the data will be deleted as soon as you clear them using the app.
