How is good relations Google search enabled?
I would like to know how good relations Google search optimized and how is the use of good relations significant.
Hi Aubrielillian,
Definitely it make good relation from every aspect because you can type only a word if you didn’t know what can I type in detail to find my required detail it will helps you this is the biggest achievement by Google its user friendly.
As everybody knows good relation source is standardized vocabulary for any company’s product and price. Many people view it and this will increase there product visibility then as well as demand so it makes good relation
When not announced that Google is using good relation data price for improved snippets, collected data reports that its the good relation rich markup in there page which causes the clear display
You can see in parallel multi techniques are used by Google for extracting and identifying price information from there pages, good relation rich metadata in RDFa, test based heuristics from HTML Doc, markup using micro formats supported by Google and shop template based heuristics.
Notifications
