1. The best thing is you should be specific in things that will you search. Like in Microsoft what do you want to search about them? For an example you want technical support from them you can search for Google "Microsoft support". And the support website will appear.
2. You can also use the custom search of Google. For more websites and specific webpages you want to search.
I hope this suggestions will help you. And have a nice day!
Its very simple just type <keyword(s) -site:http://"site which you want to exclude from search" with your search it will work for you.
For example: If want to search about HTML in Google it will always give you this site w3schools.com in search result but if you don't want to see w3schools.com in result then use.
Type in search box: html <keyword(s) -site:http://"www.w3schools.com" then press enter or click on search.
You have to go Google advanced search. Type the unwanted keyword or the site name in the field that says ". But don't show pages that have. Any" And you will exclude a specific site or keyword.
You can found specific website on Google just putting full website name, here you must be so careful about spelling of website name. The keyword that you use to search a specific website it should be very specific for that website. Adding extension is important to search a specific things in Google. Adding extension means .com, .org, .net and for looking pdf document .pdf .
1....
