How Google chrome and other browsers write logout source?
Asked By 7060 points N/A Posted on -
In our daily routine work we do much work with the internet so this is very important that how famous web browsers get logout sources and how they use it in their system and how they create it?
Answered By 0 points N/A #195399
You want to get knowledge about this I am giving you source code for your help and that is on click=”login ()” for one and logout () (“<script language=”JavaScript”>”);   Response. Browser logout source code can be write in java, C++, php and other programming language but you need to make sure when you will write code it has proper classes and parent class otherwise it will not support and will give you an error.
Hopefully this can help you better Thanks.
Raun Nelson
