cristine223
Posted on - 10/15/2011
I want to gain access to the Google Ad sense ad’s on the Drupal 6x. The problem is that I do not know how to get access to the Google ad sense? If searched many blogs and articles about this but I cannot get the proper instruction about that. Or if I got some instruction about it so that will so difficult and I cannot understand where to start the work. So please tell me how to reach
Thanks
Allan O
How to got access to the DRUPAL 6x?
This is a software that is free to use by anyone without paying a single cent. When installing the Google Drupal 6x there are tools that you must have this are tools like plugins, Exporters, AJAX responders, forming tools, object cache, context, modal dialog, dependent, form wizards and CSS tools.
Check that you have all this in place to be able to install Drupal 6x and access Google's Ad sense. This tools are all there to ensure you can access a wide range of sites using it. There are other most recent versions which you can get and install at no cost like the Drupal 7 and you may check the most recent models or versions and install if the Drupal 6x proves stubborn.
