Hi everyone, i hope you have a good day ahead. I'm going to ask on how to have auto rotate wallpaper Mac in Osx? How can I make this possible? What are the steps needed for me to rotate various image types especially wallpapers. I hope you could help me with this one.
How to have auto rotate wallpaper Mac osx?
Hello Roman,
There is a third party software which provides an auto-rotate function to all of your images.
Some software has the capability to auto-rotate and enhance batch images which will make your work a lot faster.
You may want to download iPhoto Batch Enhancer 3.5.1 and BatchPhoto The Fastes Photo Editor
Both of these software applications offer a free trial.
A tutorial is provided in the website.
I hope this answers your question.
Hi Roman,
I have read your problem concerning the rotation of wallpaper on mac OS x.
1.Click on the logo at the top left corner of your screen and then select the system preferences .Go to the system prefences pane click on the desktop and screensaver button and select the desktop tab.
2.Then you can pick an image folder from what is available to you by default, or you can add a new folder by clicking + to add a new field.
3.After you have selected the folder from which you want the wallpapers to be picked From check the checkbox next to the Change picture option below the images.
4.And now you can set the rotation time to what you want. You can set the interval to 5,10,15,30 seconds,An hour up to every day.
