ijap1012
Posted on - 03/22/2012
I want to have a connection between to computers both windows 7 just using a utp cable, I am using this a way to transfer my files from one computer to another. What kind of cable would I use straight or crossover? And do I need to use a program for a faster transfer speed using the utp cable? And do you have suggestions?
How to have a fast connection pc to pc
Hello Ijap..!!!
To perform the speediest surfing you simply alter the settings available in your networks in which first connect the network and made the connection to internet successful.
As you said you are using utp cable there is nothing problem with that as you can use it for surfing and for speeding up the net you just do the following with internet settings.
Go to settings of Internet and then click on Ipv6 protocol then change the speed in dropdown list to maximum as now you can experience high speed.
Now just restart the system to apply for the modifications and LAN cable speed is more when compared to this utp as the LAN will be faster and convenient.
Thank You.
I have a connection between my pc and my brother's pc and I was looking for a way to make it faster. Then, yesterday I saw this post and tried the solution provided by "Hoting Gracia" and it worked. I wanted to thank "Hoting Gracia" for it and also techyv.com and the "Ijap1012" for asking this question
