I want to have GOM Audio Player on my laptop and make it as my default audio player. Please send me the link on where I can download the player and the method on how to make it as my default player.
How to have gom audio player only in my laptop?
Depending on your OS or the customizations you've made on your laptop, each OS comes packaged with a default media player.
Windows for instance has windows media player as the default media player but why keep it on your system if you don't use it?
1 Go to control panel > Add or Remove Programs > Select Windows Media Player > Choose un-install or You could partly remove windows media player by clicking all programs > Windows Media Player > Un-install or delete depending on the option your O.S will offer.
2 Repeat procedure one to remove any other media player installed on your system.
3 To make this process simpler download GOM player > Install it > Under the options of associate media files choose all media formats that GOM player supports Once this is done GOM player should be your default media player.
