I have windows 7 ultimate 64 bit installed and was wondering if it is possible to have multi window screen on single LCD?
If it is possible, then please tell me how?
Any kind of help would be appreciated in this regard.
How to have multi window screen on single LCD?
Hello there.
Your question triggered me, so I had to search around the net and found a possible solution.
People give different solution to this problem, but mainly the key point is that you have a single LCD monitor and want to make it a multi window.
Check this forum, (https://www.sevenforums.com/tutorials/487-snap-window-side.html) and tell me if this helped you. Feel free to contact me further, since I am also interested in the final solution to this problem.
I`m hoping that this helped you, and I hope you will write me f it was a solution worth trying.
Regards.
Latest technological advancements have paved the way to have multi window screen on a single display.
The WinSplit Revolution can divide your LCD screen in 8 different windows or you can assign your custom settings also.
Check it out on https://maxto.net?from=winsplit-revolution.com/
I hope this helps
