How to hear audio from received call number in vb6?
I can not seem to hear anything when I received call number in vb6. How am I able to hear audio from my received call number in vb6?
Hi Shawnj Cruz,
I made a brief research about your concern and I have seen some possible solution with your concern. I think it is the best way to join some discussion of the same topic on forum like the link that I have attached below.
Forum: getting call received phone number from modem through vb6
Hope it would help you.
If you can't hear anything when receiving call number (incoming call) in V6, I suggest you check the V6 settings and make sure that incoming calls are no set on silent and mute. If you see an indication on the switch, it means that the phone is on vibration mode. Switch it to ringing mode and you should be all good.
If the problem is still there, I suggest you should reset the device.Â
 I hope this information will help you resolve the problem.
