How to hide addonchat grey window while using webcam
I have installed a real-time Java Chat Software named addonchat, while using a webcam its chat windows is around the floated addonchat gray window, how to hide it.
Hi Michael,
I have heard a lot about addonchat, it is suppose to be very successful online free chat software that runs on a Java platform.
If I am not wrong, when you start the web cam you are getting the chat window over addonchat window. A lot of people face the same problem when they integrate the software into the website. The main cause for the problem is because the chat is not aligned in the webpage. You can reconfigure the webpage so that it will accommodate the chat window, or the other thing you can do is contact the customer support for addonchat.
Addonchat provides its users with free 24*7 support to its customers, so in case you are facing any problems with the same, then you can contact the customer support and they will get the issue resolved for you. Also make sure you are using a compatible browser to use the application, and make sure you have the Java installed on your computer so that it will support all the functionalities for the application to run successfully.
Please make sure that you take good care and follow the steps that I mentioned, your webcam and chat window will operate just fine.
Bell Keny.
