How to hide files on your computer
Hi All,
I wanted to hide some personal files on my desktop PC. Is there a simple way on how to do that?
Regards
Hi All,
Regards
Okay, just followed your instruction, how can I bring it back again in its original directory and make it searchable again?
Try this one, http://www.file-encryption.net/download.php, this software is capable of encrypting files (like personal files, adult materials). This is what i use to encrypt personal/private files.
@ wapak11 for you to make it searchable again, if you are using windows 7, open any folder, and then you should see organize. Now click on that. Select folder and search options, then on the folder options, select view and then you should see the "show hidden files" and then click ok. Check your file on its original location, you should see it again now.
Hope this helps.
 Hello Dear,
If you want to hide your files, follow the steps below:
1. Go to Control Panel and then switch to classic view. Under the Folder Options click the View tab and then tick the Don't show hidden files, folders, or drives option. Ensure that you also tick the Hide protected operating system files (Recommended) check box.
2. Go to the file you want to hide and then right-click into it and select Properties. If you wish to hide a program or other file, it will allow you to change the icon. However, if its a folder, it will allow you to change the icon on the last tab. All the standard icons will be listed but you will notice that there are three blank areas that if you click on that icon, it will not be visible. Select it.
3. Now you have a file but with no icon, rename your file and then hold the Alt key and enter 0160 on your keyboard. You file will disappear.
4. To ensure that the file is not visible, right-click on it again and click Properties. Tick the "Hidden" option on the bottom and then click OK.
Another way to hide your files is right-click on the file and then click Properties. The Properties window will appear. Tick the "Hidden" option and then click OK.
