Hello Experts,
Yesterday, I set up my autocad 2008. Now I can't find a way to hide the menu and title bar in the autocad 2008 software. Is there a way to do that, or is it possible? Can you give me a suggestion and a solution?
Thank you.
How to hide the menu for autocad 2008
Hi Kaitlynnnatasha,
I worked on your issue and find the best solution for you to hide the Menu and Title bar in Autocad 2008.
Please follow these steps to hide the Title bar:
   Open tools window, the click on Palettes.
   Open the properties of palettes.
   Click on the Auto hide control on the title bar.
I hope it may helps you.
Thanks!
Hello Kaitlynnnatasha,
As you have mentioned you want to hide the title bar and the menu option from AutoCAD 2008. There is a simple way to do this. First launch AutoCAD, then go to the Tools menu from the Options. There you will find the Palettes tab. Select the option, now from the palettes open the Properties. In the new window you will find the auto hide control option which you need to select. Hope this will help you to solve the issue.
Thank you
