Emaily Rawa
10 points
Posted on - 11/07/2012
Hello everybody,
How to hide or delete Firefox see active logins? What are those ways to delete my Facebook, twitter and yahoomail active log in account. Every time I key in my email address in the Facebook username field it automatically show up. I need some privacy and get rid of that stuff.
Thanks and have a nice day fellows.
How to hide or delete firefox see active logins?
Hi Emaily!
Here are the steps on clearing your stored email addresses and passwords:
Click on Firefox.
Click on Tools.
Click on Options.
Select the Advanced panel.
Click on the Network tab.
Click on Clear Now in the Cached Web Content.
Click OK to finish.
If you don't want your email addresses and passwords to be stored:
Click on Firefox.
Click on Tools.
Click on Options.
Select the Privacy panel.
Select Use custom setting for history.
Check Clear history when Firefox closes.
Go to Settings.
Check Active Logins.
Click OK to exit Settings.
Click OK to finish.
Another option is to check Permanent Private Browsing mode instead of Clear history when Firefox closes.
lee hung
75 points
Emaily,
The information you are wanting to keep private is stored under what is called "cache". To clear this is pretty simple but make sure you monitor it so its accomplished each time you use the internet (just to be safe). For Internet Explorer go to the "Tools" menu on the toolbar. Once this is open select "Delete Browsing History" and you will want to select all. Next you will want to clear the "Temporary Internet Files" , "Form Data", "Passwords" and finally "Cookies" and you will do this by clicking on each one of their buttons. Once this is done you can close the Internet Explorer windows.
If you are using Google Chrome for your browser its still pretty simple. First you will click on the wrench menu and choose "Clear browsing data". Once your clearing this information be sure to clear: "saved form data", "saved passwords", "browsing history", "download history", delete "Cookies" and empty the "Cache". When you are clearing data usually if you use the last day for your reference period you will be fine, however you might need to go back further if you don't get in a habit of clearing things each time you use the internet.
Hello Emaily Rawa,
When you type in information for login, the keyword is saved in the browser. In this way the password can is also saved. Now you will be glad to know that with Firefox, deleting active logins is now easier than ever. With one click you can clear history, passwords, cache, active logins etc.
1. Open Firefox.
2. Press Ctrl + Shift + Delete Button.
3. Now a small window will come out.
4. Select the time range, check the things and click clear.
See it's pretty easy now. It will save you more time.
Hope it helps!
