How to hide trillian icon from Taskbar?
Hello Friends!
I am a new user to Trillian Chat/IM. Can anybody solve my problem? How to hide Trillian messenger icons from Taskbar?
Hello Friends!
Please follow the procedure for the solution:
1. Click on the 'Trillian Menu' then 'Preferences' and at the end 'Chat Windows'.
2. You will see 'Additional Options' there.
3. Uncheck the box 'Show chats activity in the taskbar'.
4. Close the window and you are done.
I hope this will solve your problem.
To hide the chat activity of your Trillian Chat Messenger, simply follow the steps that will be described next. This will prevent any chat activities from being displayed in your Windows Taskbar. Click on the Trillian menu, Preferences, then Chat Windows.
From the Additional Options, remove the check on Show chat activity in the taskbar and then close the Preferences. This will now disable the chat messenger from appearing on the Windows Taskbar.
On the other hand, if you want to hide the Contact List, you can do it by going to Preferences then Contact List. Remove the check on the option to show the Contact List in the Windows Taskbar when not docked. After this, whenever you want to restore the Contact List after hiding it, you can restore it from the Windows system tray.
