How highlighting text batch file
A .bat file is like any simple text file, if you need to edit its contents you can simply use a wordpad or notepad. To do this click the file, then right click choose "Open with" , then choose either wordpad or notepad, if done correctly you should now be able to highlight anywhere or edit that file.
Hi there: in order to highlight a windows batch (.bat) file, you will need to open in in Wordpad. Notepad doesn’t have the capability to highlight text, ie we cannot choose different text and background colours in notepad, although we may select the fonts ie bold , italic etc. In wordpad, go to Fonts section and choose the pointer font.
It will bring up various colors, you may choose from them to highlight your text. Before doing that you will need to select the text you need to highlight using the mouse. Hope that helps.
