How I can Check nokia s60 wireless signal strength?
Hi everyone,
I am using Nokia S60. Is it possible to check the signal strength of multiple available Wans?
Because I want to connect my device to the base station that have max strength of WiFi signals.
I need to check the Nokia s60 wireless signal strength.
Is there any way to check this?
Answered By 0 points N/A #166779
Hi
Yes you can check the signal strength of multiple available WANs by using your own Nokia S-60 mobile phone, on your mobile go to WIFI option and active it, your phone will search all available networks, you will see little network icons next to each network, these icon will show weak, medium and strong signals.
If you want to get detail information click on any icon you will get full information about this network.
Thanks
