How I can convert flv to 3GP/Mpeg4/dat file.
Total Video Converter is a perfect solution for converting videos. It supports reading and can play almost all audio and video formats and convert them into a popular video fie format. It comes with a great media conversion tool to convert media files on a faster speed.
It supports the following Output Video Formats:
. MPEG4(.mp4)
. 3gp(.3gp, 3g2)
. Game Psp(.psp)
. MPEG1(.mpg, mpeg)
. NTSC, PAL DVDÂ mpeg
. NTSC, PALÂ SVCDÂ mpeg
. NTSC, PALÂ VCDÂ mpeg
. Ms Mpeg4 AVI(.avi)
. Divx AVI(.avi)
. Xvid AVI(.avi)
. H264 AVI(.avi)
. Mjpeg AVI(.avi)
. HuffYUV AVI(.avi)
. Swf Video(.swf)
. Flv Video (.flv)
. Gif Animation(.gif)
. Mpeg4 Mov(.mov)
. Apple Quicktime(.mov)
. FLIC format(.fli, .flc)
. DV (.dv)
Just choose the file you wish to convert and select its format. Choose which format you want it to be after conversion and then select where you want your new file to be saved.
You can also use Power Director for editing videos. To download and install Power Director simply follow the instructions on the video below:
You cannot convert .flv to .dat using total video converter & it's not free to use. They will give you a limited time trial version only.
So, I recommend you to use ANY VIDEO CONVERTER. It is a free video converter and you can convert almost all types video using any video converter. You can convert AVI, MP4, WMV, MKV, MPEG, FLV, 3GP, DVD, WBEM, MP3, etc.
Here is the download link for you:Â http://www.any-video-converter.com/products/for_video_free/
If you want to convert .flv videos to .dat video you can use Free Convert DAT from FLV 1.8.4. It is also a good video converter and totally free to use.
Download link:Â https://www.movavi.com/support/how-to/how-to-convert-video-to-flv.html
