ruiz harrer
30 points
Posted on - 01/28/2013
Hi , I am using Ubuntu 11.04 on my computer, to install Windows 8 on my computer I need to create a partition in NTFS format. But I am enabled to create it. Can anyone tell me How I can create Ubuntu partition NTFS on my computer ?
Hi there,
For creating a NTFS partition you do not have to do anything from Ubuntu. Just insert the windows disk in the driver and go to BIOS and select the disk driver as booting device from the list. Now save the settings and exit from the BIOS. You will see the disk will automatically install the windows 8. Now select any other partition for installing windows and the partition will be automatically created as NTFS for windows.
Best regards,
Riley Weaver.
