My computer has been installing Microsoft windows XP so for doing my daily work quickly I need to customize the start menu as per my requirement but I do not find the way to make it.
Shall appreciate if any person suggest me.
How I can customize my advanced start menu?
Well you can customize your start menu by right clicking your task bar.
Right click on Task Bar ⇒ Properties ⇒ Start Menu Tab ⇒ Customize.
Now you can easily customize your start menu.
ANOTHER METHOD is displaying menu items as classic and setting different settings there. This way the Start menu takes up a lot less space on your screen. This is very useful if you are using a laptop or a smaller monitor.
For this again right click on the Start menu and select Properties. This time click next to Classic Start Menu and hit the Customize button.
