Hello guys I am using IE9 and I need to delete yandex ie toolbar from it.
It was installed automatically without my concern.
Please help me fix this issue with details process.
Do not ask me what is delete yandex ie?
How I can delete yandex ie toolbar?
Hello Dear,
It is very easy to remove unwanted toolbars from Internet explorer.
You can uninstall these toolbars from Add/Remove programs.
But to delete these toolbars directly from your Internet Explorer you have to do as I am going to say you.
Open the Internet explorer, click on tools as highlighted in this image.
Now click on Toolbars, then a new list will appear.
Remove the ticks from those toolbars that you want to remove.
I hope you will do it.
Thanks
