How i can disable Copy&Paste system in Windows 7 by regedit?
One great features of Windows is that it allows the user to easily access copy/paste with hot keys (or keyboard shortcuts as we call them).
However, if you are not comfortable with it, you may turn this option off.
To disable the copy/paste option in your Windows through registry editor, please follow the steps below:
In the registry every line lengthiness write (doc, txt, pdf, cs, cpp, xls, java, … ) Has an entry, and each entry has a key for the give part, so you would hit to go through and handicap them all, and the chances are real lyceum that from that punctuation on your Machine would not pass at all.
Hi , Fmnayeem1 hope the following steps will guide you in fixing of this issue.:
