toles hitz
10 points
Posted on - 01/26/2013
Hi friends,
I am using Samsung phone. Some of my favorite tunes are available on iTunes. How I can download music files on my Samsung from iTunes? I really want iTunes for Samsung wave. Your ideas and suggestion will be appreciated.
How I can download iTunes for Samsung wave
Wassup Tolez, I believe I can be able to help you solve this question to the best of my knowledge and ability. For Samsung doesn't support iTunes like the Apple iPhone, you will therefore need to download a software to convert the music to the format the phone supports such as aac, midi or mp3.
You may first need to download the software from iTunes to the computer then to your mobile device for downloading directly may cause the songs not to play really as well! This software can be downloaded from the website. Ensure to change the preferences from preference settings.
You can then follow the prompts to install it to your computer.
After installing the software to your computer, you can then select the music files from iTunes you want to convert so that they can be compatible with your mobile device.
I hope this helps or solves your problem.
Thanks and regards.
That shouldn’t be hard if you simply want to download songs with iTunes and transfer them to your Samsung phone. First thing to do is download your preferred music with iTunes. Start iTunes then search for the music you want to download then download them to your computer. Download all the songs you want.
Once you have all the music files downloaded, go to the media folder and copy the files you want to transfer. Start Windows Explorer then navigate to “C:\Users\[username]\Music\iTunes\iTunes Media”. Locate the music files then copy them to a new folder. Once all files are copied, you need to download Samsung Kies. Go to Samsung Kies download page and download the version designed for your phone.
If your phone is running on Android 4.3 Jelly Bean or higher, download Samsung Smart Switch otherwise just download the native Samsung Kies. Samsung Kies supports Windows XP, Windows Vista, Windows 7, and Windows 8.x. It requires 2 GHz Intel Core 2 Duo or faster processor, 1 GB RAM, 500 MB free space, 1024 x 768 minimum screen resolution, and Microsoft .NET Framework 3.5 Service Pack 1.
For media playback, it requires Windows Media Player 10 or higher and Microsoft DirectX 9.0c. For Samsung Smart Switch, it supports Windows XP Service Pack 3, Windows Vista, Windows 7, and Windows 8.x. It requires 3 GHz Intel Core i5 or faster processor, 512 MB RAM, 200 MB free space, and 1024 x 768 minimum screen resolution.
For Windows XP, Windows Media Player 11 or higher is required for media playback. For OS X, it supports OS X 10.5 Leopard, 10.6 Snow Leopard, 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, 10.11 El Capitan, 10.12 Sierra, 10.13 High Sierra, and 10.14 Mojave. It requires 1.8 GHz Intel or faster processor, 512 MB RAM, and 100 MB free space.
Once Samsung Kies is installed, connect your Samsung phone to your computer using the USB cable that came with it then start Samsung Kies. In Samsung Kies, navigate to the folder where you copied the music files. Select them then transfer them to your phone.
