Mili Nelson
Posted on - 04/13/2013
Hi guys!
I am facing some problem.
I can't download WinRAR Software.
Because some virus has attacked in my computer with that software.
Please help me by giving some advice. I am waiting your advice.
Thanks to all to see my problem.
How I can download a save winrar version without virus?
Hello Mili Nelson,
First, I suggest you use a good antivirus to remove all of your viruses. You can use BitDefender, Kaspersky, or Norton Antivirus for the best service. Also, you should update your antivirus regularly.
Then, download the latest version of WinRAR here.
You should be able to install it without any problems.
Now, you can enjoy it.
To avoid virus attack during software download, it is always better to download it in zip format. Here, the required software is being preserved in a zipped file which actually protects software from virus.
As such, a link is shown below to download required software:
http://download.cnet.com/3055-2250_4-10007677.html
However, it is also wise to use a paid antivirus for your PC with internet security like Microsoft security essential (inbuilt with Windows 7 OS), Kaspersky, avast etc. and to keep the antivirus up to date with a regular system scan to avoid such situation in future.
