How i can fix lunch error call of duty ghosts on ps4
I am a fan of Call of Duty Ghosts. But recently while I was trying to launch Call of Duty Ghosts on my PS4 an error message is pops that is “Error CE-34878-0”. Why this error is appearing and how I can fix this problem.
Best Answer by Wagner Desantiago
Answered By 0 points N/A #185579
Error Code CE-34878-0 is related to the game crash error of COD Ghosts. To fix this issue simply update to the latest firmware which is version 1.50. Also a new patch has been released for COD Ghosts. Please apply the update.
One more thing you should that is if you are using a PS3 account to play COD Ghosts on PS4 then this error is morel ikely to occur. So make a new PS4 account.
I hope my solution helps you.
Answered By 5 points N/A #185578
Hello Taylor B Campos,
Battlefield 4 of PS4 version is currently not in a good shape. It is having some crash issues, complained by many in different forums and sites. I researched about the problem got a solution, but it is only temporary. Try the solution below and check if it is resolved.
1. First make sure Battlefield is not running currently.
2. Navigate to > Settings > PSN > Sign out.
3. Now offline Battlefield 4 and then start it.
4. Go to your profile by tapping the PS button when you are at the main menu.
5. Now log in to PSN.
6. Now get online, choose multiplayer and start playing.
7. Now after you play some rounds the error "Error CE-34878-0" will pop-up again.
8. And start step 1 again.
Note: This doesn't solve the problem completely. It will prevent the game from crashing that means you will be able to play for some hours. Sorry to say this but there is no perfect solution for this as this game may have internal problem in PS4 version. So play like this and wait till the solve the problem.
