Baribd
Posted on - 09/23/2011
I purchased a domain name and hosting space so now I would like to install WordPress personally through C panel without FTP, is it possible?
If possible, I need to know the details information so that I can install it without helping others.
john.s
How I can install WordPress without FTP?
Almost all the webhosting companies offers fantastic and other installer packages in which WordPress is also included, through fantastic you can automatically install WordPress with simple clicks.
But if you want to manually install WordPress by using file manager then there are some complications. Because during installation different files need different permissions for working correctly and it will be very complicated to install through file manager,
So i will not recommend you using file manager for WordPress installation.
FTP is the best option or use fantastic.
Here is the procedure for WordPress installation through fantastic or zacky tools installer.
Click on
Zacky Tools Installer
Now click on wordpress and follow instructions. it will simply ask you where you want to install and db username and password, plus admin user name and password options.
Dear,
Wordpress is very well known software. It is very simple to install, it takes less than 5 minutes to complete. You can install WordPress in two ways, automatically or manually. If you have no auto installer on your account then you can install WordPress manually.
To install WordPress manually without FTP, you can watch this video:
www.youtube.com/watch?v=UEH1X_MhkAs
Thank you.
