How I can promote Aptare views in ODBC?
Hello expert, I have downloaded and installed ODBC drivers on my PC. But still I am getting more errors while using this driver to Aptare views. How I can promote Aptare views in ODBC?
Hello Gerardo Thomass,
I think that you have aptare connectivity problem you have to reinstall the software and after that you have to again connect it with the ODBC. Here is the link from where you can get the latest version and error free version. You can connect them with Oracal or SQL . Mostly when you have connectivity problem then you have some problem in your software ODBC are not mostly effected.
