I try to run Views on my Mac. However, there were some problems that I cannot do this because an error comes on display saying that my code does not match with the registration. Anyone can to help fix this problem. What is the best way to can run views on Mac?
How I can run eviews on Mac?
Hello, Alison,
I have understood your Mac's Issue. You can follow some instruction. Firstly, clicking on “Application” icon, go to the “Finder” menu. Then, select “Utility” folder.
Since getting this dialogue box, you can select the following options. In this way, I think you can run this view on your Mac. If there is a still a problem please contact with forums.
Hopefully, you will get his.
