How I can setup in Cisco router?
Hello
I have bought a Cisco wireless modem few days ago. I have set up it. Now I want to change my router name and password. I have went throw Cisco site 192.168.0.1. But it wants password. Can you give me Idea what is my password here? And what I will do next?
Thanks
Best Answer by DaisyWhite
Answered By 5 points N/A #89845
Hi Ahmad Salman,
The password would usually be the serial number or its last 7 digits.  But this would depend on the make and model of your Cisco.  If the serial number does not work tell us the model number of your Cisco still found at the back or your device where it has a white sticker on it.
On the white sticker, you'll find the Serial number, MAC model number, etc.
Hope this helps. 🙂
Answered By 0 points N/A #89846
Oh my, why didn't you know the set password for your Cisco router. You said that you just bought it then I suggest that you have your router Reset. Then use the installation CD and then follow to guide on how to install your Cisco router. This will reset you password to the default which is blank but during the installation it will also ask you to enter new Username and Password for your router but this time make sure to make a backup of the copy of the Username and Password on either your desktop or anywhere safe but free to access.
