kamal Ahmed
Posted on - 09/27/2011
I have been using macro in Microsoft Word XP but after installing Microsoft Office 2007 I cannot use the macro in Microsoft Word 2007 because here everything is new so I am in bad situation but it is very essential for me.
Can you help me to give me detailed suggestion?
AizaM
How can I use Macro in Microsoft Word 2007?
Here's what you are going to do, in order for you to use the macro in Microsoft Word 2007. You must do the following steps before using this macro:
1. From the view tab click the "macros" you will then be presented to sub menu, click the record macro. And after clicking the record macro, there is a dialog box appears and requires you 2 options to assign macro. It is up to you if what do you desired the accessibility level do you want the macro to be used.Â
2. After providing the necessary detail, select "button" after that a screen will show up.
3. Select the macro you just created and click the "Add" to add it to the quick access toolbar.
4. Then click ok for the dialog box appears.
Then you can use the macro now, by simply clicking the Quick access toolbar found at the top left of the Microsoft window especially to the MS Word.
