I wanted to start customizing my report so I hit the Configure option to start the “Report Customizer”.
I didn’t expect that I would encounter a problem. A window popped up saying
B2Win Wizard
Can not open the Wizard. Please click on Help > Update Components.
How do I fix this error?
How I fix this error in B2WIN?
It seems the report customizer has a problem and therefore you will need to fix it. The workaround I will suggest for you is as follows:
Update the report customizer application, so that old database components that may be malfunctioning will be replaced by new database components that do not have a problem. You can update the application directly online.
Restart the application after closing all its processes in the task manager. It could have been a temporary bug that will be fixed after you restart the application.
In case the problem persists, you will need to perform a reinstallation of the application to fix any bugs that it may be having.
Regards
Thompson Locker
Try following what it says and go to “Help” then select “Update Components”. See if this fixes the wizard. If this doesn’t work, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select B2Win among the applications and click “Uninstall”. Follow the normal uninstall process.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then install B2Win back. If the problem continues, download and update to the latest B2Win Suite.
