Hello!
I have a Sony Ericsson WiFi mobile phone.and I have also WiFi internet connection, but I can't access internet by WiFi with my mobile. When I connect I give Wep key but always says connections failed or error or lose. Now what can I do for this problem?
How I Setup Wifi On My Mobile?
Here are the steps to set-up Wi-Fi;
Go to Menu, Settings, then press Select.
Turn on Wi-Fi, then list of Wi-Fi network detected.
Click on the desired Wi-Fi and type WEP key.
Select the Options to Auto-Connect when SSID is detected.
Press OK and this should be the solutions.
Possible issue why your Wi-Fi is not working is because of invalid WEP key information. This information is crucial and important when connecting wireless connection. It may also possible that Wi-Fi of your phone is not activated, check if the Wi-Fi network is turn on.
If everything failed, verify with other computer of yours if the Internet is working because if not, you need to power cycle your equipment, modem and router.
