How i use Android visual styles for win 7
I am using win 7 i am searching how i use Android visual styles in win 7 please help me and send me URL or screenshot to solve my issue as soon as possible.
You can have those Android visual styles on your Windows 7 by installing custom theme packs,
Here's the one for the Android theme
And as for the installation instructions look it up here
This is a brief Instruction on how to Install Windows Visual Style for Windows7.
First Download the Universal Theme Patcher(V1.5 Build20090409) > Install>Download Windows7, Android Theme> Extract the Theme> Copy Theme Folder> Paste in C:WINDOWS> Resources> Themes> Run Theme> Click Android 2x
To View Screenshots and Information regarding Different Windows 7 Visual styles just click on the link.
Zsyrl
Since you are looking for the procedure on how to properly install a theme or particularly an Android theme on your Windows 7, you may find different solutions and procedures on its installation on websites offering Android theme packs for Windows 7. Not all themes have the same installation procedure because it depends on the theme’s creator on how it can be installed properly.
But most of the time, installation procedures are made easy because theme packs are usually in the form of an executable file [.exe] where it simply needs to be launched and it will then automatically installs the theme on your operating system.
You don’t have to do anything like copying the theme files to a certain folder in the system directory, enable or configure a setting, and others. You can install the theme with a simple click.
If you already have downloaded an Android theme for your Windows 7 but doesn’t know how to install it, you must visit the website where you downloaded the file. If the file is in a form of a ZIP file, extract the contents of the file using WinZIP or any extractor to a folder then open any executable file it may contain. If the file you have downloaded is already a “.exe” file, simply double-click on the file to start installing it. Just follow the succeeding on-screen instructions.
You may also try downloading and installing this Windows 7 Android theme pack I found from here.
It has versions for 32-bit and 64-bit of Windows 7. Download only the version appropriate for your operating system.
Notifications
