How i will compress my photos in my pc?
Usually i gathered my all pictures in my computer from my digital cam. My cam is 12 mega pixel and good regulation But all picture size are really big. Mostly are 2mb so when i try to send my picture,i face problem to upload. I cut'ed the picture but still big. Will anyone tell me how i will consume my photo size?is there any software for it?How i will use to make it small size?
Best Answer by jackbeen
Answered By 0 points N/A #128020
To reduce the size of you pic you have many software but again it will reduce the quality of your picture. and if you want to compress your picture add all the picture in one folder. you must be having adobe winrar achiver. right click on the folder and select the option compress.
This will compress your picture and make it one folder. but if it still no uploading then you must have a Photoshop open your picture
1) change the format of your picture from jpg to bmp or other format which require less memory or make low resolution of your picture in adobe this can also reduce your picture size.
Hope this help you and solve your problem. thanks
Answered By 0 points N/A #128022
Many solutions there and Try those steps. First try photo editing software and cut your photos boarder lines, It will help to reduce file size, Then try to save it as a different format. Finally you can reduce your picture quality. Next time change your camera quality as low and your images will be small.
