frank logan
10 points
Posted on - 01/28/2013
X10 Commander is an X10 Controller Client for the iPhone/iPod/iPad/Android and is a native iPhone application that allows you to control up to 60 X10 devices anywhere in the world.
But now I am using Windows 7.
Can anyone tell me How I will find x10 commander for windows 7 manual ?
Hello Frank,
With x10 Commander basically you can control devices from your iPhone/iPad/Android phone. With this you can lot of things. tasks.
For example tasks such as close the garage door while you are in bed, switch on the lights while you are in bed can be easily achievable. x10 Commander is available for Windows 7.
I'll provide the link to download x10 Commander for Windows 7 and the User manual.
Download x10 Commander for windows 7
Download User Manual of x10 Commander
Thank you
Rubi Sharlene
